A body tubular K member
572cuda
Active Member
Tennessee
Rating - 0%
0   0   0
A body Tubular K member, upper control arms, I also have the coil overs and wilwood brake set up. 900. for k frame and rack and uppers, 500 for the brake kit and 300 for the coil overs. I had previously posted these in the wrong forum.
Brake kit.. Does it have spindles?? If not are they a Early A-body or 73-up LBP 5-on-4.5" spindle? for drum or disk?
The brake kit is wilwood# 140-2723-B 65-72 with a 10inch drum, I don't know who the frame is made by, and it has no mounts for a motor plate
What brand are the coil overs? What is the spring rates? Can you post pictures? I can send you my email address if needed. I would also be interested in the rack and pinion, can you give me some details on it? Like brand and a better picture of how it mounts, clamp on or bolted with bushings? Thanks
you must be on the Alter, payroll, nothing but their stuff on their site. I realize you are perfect, and some of us are not.
What the hell does that mean? The question was asked what brand it is and I stated it looks like a Magnum Force early unit. I did not bash your post in any way shape or form! Nor did I try to push another maker of the units.:wack:
FYI.....there is now an infraction for inappropriate comments in sale ads, so be careful what you say folks.....
572Cuda, I think you responded to the wrong party. Bakaruda did not take a shot at you. If you want to respond to a particular party, go to that persons response in your thread, select quote and then respond. I think you got the wrong guy. Good luck with your sale.
Thank You
Sold the k member and upper arms on racingjunk still have the brake kit and coil overs, I got my www.Control Freaks.com front end, I love it,
