[WANTED] A couple items for a '67 Notchback Barracuda
tubbedamx
Location Boise, Idaho
Boise, Idaho
Have a '67 Notchback Barracuda and I am looking for a couple things.
  • Deck lid upper and lower mouldings. Straight with no dents.
  • Black door cards (All 4)
  • Headlight switch
Shipping to Boise, Idaho 83709
The headlight switch you can get new at your local part stores, Rockauto, etc... That replacement will include a male spade terminal for a much needed ground wire attach point that your OEM switch did not have.
Door panels.... any can be color matched with SEM Landau Black, spray cans off the shelf. That is if you can find good used. That vinyl would shrink, pull away from the board, wrinkle. Moisture caused the boards to warp.
Those trunk trims that aren't dinged up? That'll be a tough find too.
If these parts survived the test of time there would be no need for the aftermarket to reproduce them. Best of luck though.
Buying a used headlight switch when you can buy a new one is like buying the used underwear.
I believe they repro the 67 upper and lower trims. Do research and get an estimate of repairing and detailing original trim compared to repro.
1967 Plymouth Barracuda Parts | MN1406 | 1967 Plymouth Barracuda Trunk Lid Molding | Classic Industries
