Something I learned on the weekend.
If you are planning to fab your own frame connectors, make sure you measure how wide your sub-frames are first. I used the measurements from the Big-Block-Dart tech article and they are wrong. To make a long story short, I was in a hurry and didn't measure mine. BAD MOVE!
The tech article says to use a 2" by 3" by 53" piece of rectangular mild steel. Well my frame rails are 2 1/2 inches wide. So no matter how you look at it the 2x3 is not going to fit right. I was able to cut and weld things so they fit right and will be just as strong but it was a pain in the *** to do and it only cost me some time but that was time I should have spent elsewhere on the car.
Just thought I would warn everybody to not take things in tech articles as being gospel.
Jack
Jack
