JGC403
When assembling the 833 the proper thickness selective snap ring or the shims that are available as a replacement for the snap rings are used on the input shaft after the bearing is pressed on and after the rear bearing is pressed on the mainshaft. Are they used anywhere else?
The snap ring that retains the 1-2 synchronizer assembly is that supposed to be a selective snap ring?
