Kraftei
Active Member
My 72 (second last owner) had the A833 gone over over a few times for making noise. He also balanced the drive shaft and had the rear end looked. I adjusted the shifter linkage and changed the oil, the oil looked like someone put gold sprinkles in it. I thought I might get lucky with a few changes I made.
I finally finished with my restoration/mods and took it out for some carb tuning (new carb) and the 4 speed was thumping like a disco (after a few hard runs). I am getting 3rd gear rubber now. There is no doubt now.. where the noise is coming from.
Because the transmission has been gone over so many times I would rather just swap it out. I am going to send mine back to the shop that built it (and rechecked it numerous times) for analysis. The second previous owner would like to resolve this, as it only has 200 miles on it since he had the 4 speed built.
