Sasalmond
Hopefully you guys can shed some light on my issue, i have been struggling with my 73 dart /6 ac. I have got my blower to finally function and the system appears to have refrigerant in it though i am not sure how much or the last time the ac was ever used on the car. I jumped the pressure switch to see if the clutch would lock and i got nothing, i than jumped the clutch to a 12v source just to make sure it still functioned and it locked right up. so after some reading in the FSM i noticed a second switch they call an anti freeze switch so i went ahead and jumped that switch and again the pressure switch and it finally locked in. So i assume that the system may be low due to the fact that i had to jump the pressure switch also but my question is would low refrigerant also cause the anti freeze switch to not engage or is that a whole different issue all together. Also i did test everything first with my multi-meter and i was only getting .03V at the pressure switch with no jumper wires being used.
