"Actual Match Race" 1969 440 'Cuda vs 1973 Firebird Formula 'SD-455'
Ok. So 20 more HP. You're right. I was wrong. Big whoop. lol
Show me a Pontiac document that raised the HP rating. This I gotta see. Regardless, it was an underpowered luxury hot rod. Too heavy to get out of its own way in stock trim.
Easy 'Triple-R',
You're the one who questioned me.
Never do that again,,,,,,,,,ever.
Now, in 1975 how did I get a 1969 440 'Cuda to hit 12.80's @ 112 MPH
thru 'slightly modified' Stock Exhaust and 3.91 Gears would be a good question.
Easy 'Triple-R',
You were being pulled by a 1968 383 roadrunner?
Couldn't resist:poke::poke:
Yes, we always used 383 Road Runners for 'Tow Cars'.
That, and to laugh at.......
Question,...,'How do I get my 383 Road Runner to run in the 13's.
Answer.......'Push it off the side of mountain.'
True Story..
Joe-Nip,
A 'Factory Stock '1969 440 'Cuda ~ 'Automatic' and w/3.91 Gears and stock E70 x 14' Tires.
440/375 HP {NHRA re-factored to 356 HP}
'1/4 Mile' Performance = 13.80's @ 103 MPH.
They only came thru with 3.55 {Standard Gears} and 3.91 {Optional}.
Automatic 'only'
Tires ~ E70 x 14" on 14" x 5.5" Rims
1969 Performance Magazines had them running anywhere from;
* Best........... 13.63 @ 104 MPH
* Average......13.98 @ 101 MPH
Other Performance Results
Detroit Press {Performance Test}
* 13.17 @ 108 MPH {w/Kustom Headers ~ 4.30 Gears ~ F70 x 14" Tires}
Joe-Nip,
The Gearlords Racing Club out in Altadena, California tested a new
1969 440 'Cuda in February 1969.
They took it out Lions Drag Strip, and could not get the 440 'Cuda w/3.55 Gears
to hook up with the 'little' E70 x 14" tires.
Even their best Mopar Drivers could not get the 440 to run any quicker
than 13.90's @ 102 MPH, and with every 'Off-The-Line' technique they had up
their sleeves.
Finally they gave up, and popped on a set of Prowler 8.00 x 14" Cheater-Slicks
with 14" x 6" Cragar S/S Chrome Wheels.
They were able to 'smoke' some incredible runs of 13.35's @ 106 MPH with the
28" tall Cheater-Slicks.
The only other up-grades.
* Champion UJ-12Y Spark Plugs
* Re-Curved Single-Point Distributor
* Re-Set Pump-Shots on the Carter AVS Carburetor 750 CFM
Error Fred,
~ 1973 Pontiac Firebird ~
Production Numbers
Model ............................. 4-Speed ........ Automatic ........ Total ...
* Formula 350 ............................................................. 4634
* Formula 350 'Ram Air' .................................................. 137
* Formula 400 ............................................................. 4288
* Formula 400 'Ram Air' .................................................. 234
* Formula 455 ...................... 237 .............. 503 ............. 575
* Formula 455 'Ram Air' .......... 51 .............. 104 ............. 155
* Formula 455 'SD-455' ........... 10 ............... 33 ............... 43
* Trans Am '455' ................. 1420 ............ 3130 ........... 4530
* Trans Am 'SD-455' ............... 72 .............. 180 ............. 252
This thread reminds me of one our members with a 360 powered '68-'69 Barracuda using a 455 Firechicken as his whipping post.
Seriously, every grudge match he'd beat the Poncho by a good 1.5 on the 1/4 mile.
NHRA 'corrected' Horsepower Factor Changes by Year
1969 'Mopar' - 440/375 HP
1969 ........ 375
1978 ........ 366
1979 ........ 356
2008 ........ 350
1973 'Pontiac' SD-455/290 HP
1973 ........ 310
1975 ........ 340
1978 ........ 345
1973 'Pontiac' 455/250 HP
1973 ........ 290
1978 ........ 310
didn`t read all the posts here. we put a 68 street hemi in a 66 belvedere 11, would kick sd 455 fire birds a$$ on the hiway easily !
1973
There were several 455 HP combinations. Remember too, that the 1973 Firebird's
were loaded with accessories and a few slow-down items.
* Power Steering
* Power Brakes
* Air Conditioning
* Air-Pump
* Transverse Muffler
And those long *** doors have got to weigh a ton too. Even the subframes could knock out an elephant.
