Adding A/C
HellerHighwater
I am working on adding back the factory A/C to a 72 340 Demon. I have two sets of compressor brackets and all pulleys, still need the alternator bracket(s)
- Does anyone have detailed pics/diagrams of how the brackets go on? I have googled and cannot find any diagrams or info on how to get it to clear the heater hoses. I figured if it came with A/C I may as well try to put it back on... any help would be appreciated -
Yes, but I am having trouble getting it to clear my heater hoses on the 340... Also, pics of the top of the condensor and how it mounts to the bracket. I would be interested in the A/C bracket. Thanks!
cant help you with the heater hoses
as you can tell in the second picture, mine is looped right back into itself
(I got good reason the believe my heater core is leaking)
the condenser I need to check into
I may have pictures of it
does it look like my 360?
the "inner" part of the alternator bolts to the A/C mount
I have one of the alternator mounts for sale for $15.00 plus shipping
http://www.forabodiesonly.com/mopar/showthread.php?t=320550
Thanks for the pics- I have the front bracket on the A/C compressor, and the large curved lower bracket for the alternator mount. Does anyone have the remainder of brackets for a 71 small block with A/C? I need the front upper bracket that mounts to the alternator and compressor, the back lower bracket that bolts to the block and back of the compressor, any other braces/brackets for the drivers side, and the bolt and spacers for alternator...
Thanks!
