Adjusting float with electric fuel pump
If your still having problems,turn your idle up! You said it idled down to 50rpm then died. Sounds like the throttle is almost completely closed. Adjust idle speed up with the throttle stop screw.
Did it backfire thru the carb? If so, check the power valve, it could have blown it. I believe that will also cause fuel to be sucked out of the boosters.
