Oh what are you setting the valves at?? 0.022
dot to dot is when #6 is on compression
Val, with #1 at TDC compression, pull the dizzy and where is the slot on the gear pointing? In my 69 factory shop manual, it shows the "slot" pointing to the 1st intake manifold bolt on the drivers side.(pic says for 340) but I think its the same for all sb's??
What are the chances that the fuel is poor? Been sitting? Tried any fresh, down the throat, or starting fluid?
HERE's a story. In the 70's a then friend was trying to start a brand new 396, 57 Chev. I KNEW it would run--I helped install the cam and set the prelim valve lash.
He screwed around most of a Sat morn, and finally came and got me. Says "we're priming it with that Pepsi can full of gas"
I sniffed it to make SURE I wasn't gonna pour Pepsi down the carb, and said "go get some gas."
IT WAS JP-5!!!!! (Kerosene to you civilians, LOL)
Steve....thats where it's pointing.
Well sounds like you are 100% with the timing....I was really hoping I would make a difference dangit!! :banghead:
Proper distributor?? Ballast resistor??
advance the ignition timing while turning motor over counter clockwise.
won't let me watch the video, it says i have to log in.
It hits against the starter if I go too far advaced.
This I don't get. "Hitting against the starter" is caused by compression, fuel, and spark, and too much advance. If it's got "enough" to hit on the starter, then the darn thing SHOULD run.
