la2alle
Bad Fish 65
Ok, need some advice on what you guys think I can do to make my car run better. I just started a rebuilt 273 from a 1965 barracuda (automatic). What I have in it are the following;
bored .30 over / 10.1 pistons / dont remember what type.
302 swirl port heads / rebuilt with the bigger valves
Comp Cam specs ADV DUR. INT 268 - EXH 268
DUR @: .50 218 218 Lobe SEP: 110.0
Valve lift: 454 .454
With comp cam lifters and adjustable rockers
Holley #80457 600 cfm
Weiland Intake / Action plus # 8007
Mallory Unilite distributor and coil
Rebuilt 904 tranny with a quick shift kit.
Problem is the car is not accelerating as I think it should, kinda sluggish. Could the Carb be to big? advice would be appreciated.
