stroker402
1968 dart GTS convertible
I purchased a afb 4294s carb that was rebuilt by previous owners. 67 commando carb . Does anyone out there have the oem jet and step rods numbers . I opened this carb up before I installed it on the car to do a quick visual of everything inside the carb, It all looked to be there and correct. float levels were even on each side , didn't do a measurement check on floats though but when I tried to start the car it would not stay running . maybe the float levels were not set correctly . needle and seat issue . the accelerator pump was new , squirters were shooting gas out , so that was good .I'll pull it off the commando and go thru it . blow everything out . reinstall . hope for the best.
Here is what I have inside the carb. can someone varify that these numbers are the oem stock components inside this carb?
jets # frt. 347 rear 489 ... orifice size .047 frt .089 rear
step rods 16-403 .069x.058x.065
springs gold / yellow
squirter .... no number stamped on it.
pump new .
pump new .
