DesertRat
Leading edge boomer
Looks like it's in a dedicated compressor room to me. A stellar install I do believe.
Now my next stupid question is, is sweated copper pipe SAFE for this?
Yes, what you don’t want to use is pvc pipe, with which you will loose the cooling/condensation effect anyway.Now my next stupid question is, is sweated copper pipe SAFE for this?
A buddy uses a similar setup for a cnc plasma cutter, except his are VERTICAL so that condensate can't climb up n' out.
I would also recommend doing this before your filter, as it will force the moisture out of the air with cooling, so you're less likely to overwhelm your filter. Less moisture in the filter means less moisture out.
If you use copper tubing, reminder that there are three wall thickness pipes (that I know of) and I think they're , K, L, and M.
I don't know which is which, right off but this is not the time for Chinese copper pipe. There might be a pressure rating on the pipe itself.
These are good for catching the water and final filtering air. Motor Guard: Air Management
I made a coil of 1/2"X 20ft pipe with air fittings on each end. I then just put a regular airline water trap on the outlet. It allows the air to cool enough for the water to drop out and be removed by the separator. Just being air cooled, and possibly the spinning air, works pretty well for getting water out. The coil is small enough and tight enough to fit in a five gallon bucket so if I'm painting I can put it in a bucket and add a couple of bags of ice and top the bucket with water. It then works like a refrigerated separator and makes a regular bowl style water filter very effective.
I'd be glad to post a photo but I loaned it to a buddy from out of town who was getting water in his sandblaster so it would plug up. He said the cooler cured the problem. He plans to be using it until the first of October, as he is having a guy make him one and the guy won't have his ready until then, so I can't post a photo until he returns mine.That sounds like the kinda cheapery I am talkin about. Can you post a picture for me?
I connect this right off my compressor.
https://www.amazon.com/dp/B005JDKY68/?tag=joeychgo-20
Then I ran 3 legs of copper off the compressor, up down....up down....up down..... and back up with a ball valve at the bottom of each drop. Then I connected it to a standard filter kinda like this one (this filter might be redundant but I figure it's better to be safe than sorry if painting)
Milton Air Compressor Micro Filters 1018
then it goes into this
Motor Guard Compressed Air Filters M-60
then into this
Rockwood 3/8” NPT 2 Stage Air Filter Dryer System
right at my tool I then connect this
Performance Tool Air Compressor Line Filters M695
The heavy lifting is done by the Motor guard and 2 stage desiccant filters. I attempted to just use that little filter I posted at the end and after a couple compressor cycles, the moisture just over powers it and it's useless. It's really just meant to be a last line of defense. After I did this setup, I no longer have any moisture when primering or blasting.
Somehow this below got posted in an old thread. Somehow - no idea how - but I did it.lol @ the chinkesium. I agree. Not the place. I will find out which is thickest and use that.
"All of that" is probably within my price range. Now, does any of "that" have filter elements that are actually replaced?
That looks easy enough to make. Thanks for posting that.
I would be leery of using the copper trap with full psi. BUT painting and sandblasting (where h2o is an issue) requires lower psi?? So the copper would be "safe"??
Create a bypass valve so when running air tools needing 100 psi, you omit the homemade trap?
Am I wong in tinking dis way?
From the compressor to the copper I use hydraulic hose(tractor supply). It isolates vibration. On the drops I just sweated on threaded connectors, and attached quick connects.How do yall make the transition from the copper pipe to the air fitting?
Ok so there are threaded fittings I can sweat on. I never knew all that. I know how to sweat pipe.....that's actually easy. I just didn't know what all was available.
Yeah, hold on. I'm at home but I think I got some stuff I can take pics of.Ok so there are threaded fittings I can sweat on. I never knew all that. I know how to sweat pipe.....that's actually easy. I just didn't know what all was available.
I'm planning on making mine out of type M 3/4 copper, about 30' total length. Six 5' lengths with the 90's to turn the corners. My brother in law is a heating and air guy who is gonna sweat the joints for me, and he says we should use silver solder to make the joints.
