I built an engine with a broad-flat torque curve and a small cam. And I put an A833overdrive behind it. It was a pretty good combo, if a little lazy in the performance department.
So, I got me a GearVendors, and wired it to split gears. Plus, now I had a double overdrive. When gear-splitting, the ratios are very tight, and the engine stays on the cam, and performs like a bigger engine.
The Ratios are;
3.09/2.41- 1.67/1.30- 1.00/.78 -.57, seven useable gears.
The splits are
.78-.69-.78-.77-.78- .73
as compared to
There are two A903 ratios;
A) 2.95-1.83-1.00, splits of .62-.55
B) 3.22-1.84-1.00, splits of .57-.55
If you had a regular A833, the ratios would be;
2.66-1.92-1.40-1.00-.78 od. Don't bother splitting these gears, unless you just go First and then straight into first-od, but it's hardly worth it.
You might thing that the GVod 's .78ratio is lame but, But when I used the regular A833, I shifted into od after third, making a tight split there, and then into 40d is a nice .71ratio.. No matter how you shift it, for cruising, it turns 3.55s into 2.77s, and rpm at 65 drops from about 2870 to 2240.
Which is about as low as I care to go, because any slower and my fuel economy doesn't change much, with the cam I currently have, because, the slower she revs, it gets to be darn near impossible to give her the ignition timing she craves, to be efficient. But I solved that by installing a stand-alone, dash-mounted, dial-back timing module. It has a range of 15 degrees, which I can add some to all of that, at any time, as the engine wants it.
Now, I gotta tell ya, If your aim is fuel economy, it will take many years with an overdrive, just to break even, before you ever start saving money.
A better option might be dialing in your Cruise-Timing. My experience is all with 318s to 360s, which, I have never yet had even one that had the correct Cruise Timing. All of mine, (over 55 years worth) cruising between 2250 (with 2.76s) and 2650 (with 3.23s), wanted timing of from 54 degrees to sometimes 60. Most had less than say 36 degrees. That's a serious timing deficit, especially with, as they say, it has a bit of a cam, and/or, weak cylinder pressure.
Whatever direction you go, Best of luck.
