Airtemp AC
My 1970 340 Swinger came with the factory air,shows H51 on the broadcast sheet and fender tag. Does anyone possibly have a photo of the air unit under the dash, my controls are in the dash. Need to see the grille or opening where the air exits
This is on a 69 Dart which yours will be the same. This is factory A/C.
I have one out of a 73 sport coup, if it's the same ????.....if you want to purchase....pm me
I dont know if 73 would be the same, going to salvage yard today. They did have a 69 dart 6/904 that I remember seeing that had air, hopefully the piece I need is still there. I need the vents that attach to the main heater box and mounts to the under side of dash. Thanks
I assume you have a factory A/C evaporator/heater box? If so the vent assem. fits right over the rectagular opening of the case, you just need to ad the foam strip that seals the two pieces together.
