As detailed elsewhere in this forum, I swapped in some QA1 upper control arms.
Per the instructions (and common sense) I marked the positions of the camber bolts and attempted to get them back in the same orientation when installing the new arms but they still ended up off a bit, noticeable in that I have to keep the steering wheel turned a bit to track straight. The car drives fine, stops straight and no noticeable wear has showed up yet, though I've only driven it a few miles so far.
In any case, I need to have the front end professionally realigned...but I'm also looking at a set of heavier torsion bars and fresh Bilstein shocks...as far as I know, I won't need to unbolt the UCAs again for those installs (am I wrong about that?) but these mods may be a couple months away. Should I bother with the alignment in the meantime?
Secondly, would any shop be able to set the alignment or should I look for a specialist? What alignment specs have you guys run? Any advice on settings that will clean up the handling?
Thanks for any advice and all patience with my perpetual novice questions!!
