Alignment specs?
340duster340
long island NY
Cant anyone send across the alignment specs Theyre running?
Ive a 66 dart all ffi upgrades...finall on the road and getting alignment next weekend!
Thx in advance
I can tell you my drag only 66 Valiant specs but I don't think that's what you want. Bias ply or radial? Use of car? Autocross, daily driver, trailer queen? Skosh chart....?
a little more info might help....
manual or power steering?
all OEM or aftermarket components that additional caster?
As a base with modern radials and for street use,
Camber 0*to + 1/8* Caster + 1 to +4 if you can get it that high. It's best to just match both sides for the most + .
Toe in a total of 1/8''. Now everybody has their favorite settings like all aspects of this hobby.This is just a base line for the average street driver.
  • 1/2 to 3/4 degree negative camber with radial tires
  • 2-4 degrees positive caster (try for highest amount)
  • 1/16" toe in
So get this i was doing a once over on the front end and the new idler arm from moog was bad!! Thankfully i save the old one which was still tight
Not surprised. Replacement parts are very poor quality anymore.
Moog has been terrible for years now and seems to be getting worse. I’ve been buying tie rod ends, ball joints and steering arms from Proforged, so far everything I’ve gotten from them has been good quality.
