Alternator and Voltage Regulator Questions
stumblinhorse
Grand County, CO
The electrical stuff is hard for me so I am hoping you experts can point me in the right direction. I think these are simple questions!
Quick background. Original single field Alternator and mechanical Voltage regulator in 69 318. Alternator has been out and tested and got 15.1 volt output without a lot of noise etc. So Alternator is good, I think!
I read the exact same 12.7V at the battery at any RPM. Recovers after being turned off a few minutes to 12.9V. Brand new battery.
At the "BATT" connection on the alternator with the engine off I get the same 12.9V and with Running I get the same 12.7V.
Questions:
These equal readings tell me I have a good circuit from the Battery to the Alternator?
The low voltage reading tells me that the Alternator is not sending power to the battery?
The alternator test tells me the Alternator is working correctly?
This tells me the VR is not working?
A VR like this Mopar Performance Voltage Regulators P3690732 would most likely fix my problem?
If it doesn't fix the problem, I can focus on the wiring from the FLD connection to the VR? Or I should just simply replace that with new when I replace the VR?
Thanks for the help!
Since your alternator has tested good, it is probably your regulator. Just go to your local auto parts store and get one. Don't bother with that Mopar performance one.
Test it ON THE CAR. Not that difficult Go to MyMopar and download a shop manual, and an aftermarket wiring diagram, There are also simplified diagrams there of the alternator / regulator
I divide things "roughly" into
1.....The charge circuit path, that is the alternator output, through the bulkhead, the harness, the ammeter, back out the bulkhead, to the battery
2.....The field circuit.......from the igntion switch (branches off at the coil resistor)-----to the VR---------to the alternator field
THE VR MUST BE GROUNDED. Unbolt the VR, scrape and clean around the mounting holes, and remount with star lock washers
3.....The major components, IE the alternator and the regulator
"Quick test"..........Done in the following manner, this will leave everything in the circuit EXCEPT the VR
Unhook the VR wires, and jumper them together with a clip lead. Start the car while monitoring battery positive, and slowly bring up RPM. Your dash ammeter should move to the right, and the voltmeter should climb. If it does don't allow it above 16V
If this is the case, check the VR grounding above, and if that is OK, replace the VR
I have the FSM and see the wiring diagram.
My ammeter is already bypassed. The charge circuit shows that I get the same voltage at the battery as I do at the "Batt" connector on the Alternator. So I think that tells me it is ok?
The VR is grounded to the block at the head.
So I can jumper the two connections, FLD and Ignition together? I would not have thought of that! I have a electronic ignition on the engine, any issue with that? My Alternator test said max output was 15.1V.
What I don't understand is the role of the VR I guess. How does it tell the alternator to not allow power to get to the Battery?
OK an alternator output is always connected to the battery.........the main output stud.
How it works........
The ignition switch sends power to the VR off the same circuit that powers ignition. This IS ALSO THE SENSING wire that the VR uses to "figure out" what to do.
The relay in the mechanical VR or the circuitry in the electronic one "shall we say" MODULATES the current going to the field connection. More field current= more output. As the VR senses the battery is low, it sends more field current to the alternator........higher output. As the battery "comes up" the voltage at the VR ignition terminal goes up and it "cuts back" and SHOULD normalize at nominal 14V
By jumpering the wires, you are simulating "full field" "completely dead battery" so to speak.............Again, watch your meter and don't allow RPM to bring the voltage up past 16
Your statement that the alternator will put out 15V does not mean much. An alternator that is DISCONNECTED from a load and that is spun up, with full field current can put out OVER A HUNDRED VOLTS!! (This is however hard on the alternator and diodes) IN FACT back "in the seventies" there use to be silly switchboxes sold that allegedly allowed you to get 110V (DC) out of your alternator. What this switchbox did was to.............disconnect the alternator from the VR and full field it............just like the test...........and also disconnected the alternator from the vehicle system........and connect it to a common outlet box!!!
The point? ALTERNATOR OUTPUT voltage depends on the FIELD CURRENT and the LOAD THAT IS ON the alternator output. If you have a battery that is fully charged, and no loads in the car (no fans, no big stereo, no lights etc) and you "full field" the thing, the voltage can go WAY over normal, up over 20 -25V until it damages something.
So I got my MoPar regulator and hooked it up. I am frustrated with this! I have 12.14v coming to the VR and I have nothing coming out of the regulator going to the field circuit. When I jumpered the field wire to the plug coming in it pretty much melted all the connectors in about 5 seconds, The time it took to start the the engine and walk to grab my multi meter. So no idea what to do next. Is it possible I got a another bad regulator?
Help!
Oh SHEEET. What I get for giving you shortcuts, LIKELY what happened is the field wire is shorted to ground and burned up your old regulator. Either that or the field in the alternator is shorted. However, you said you had it tested and "good." So either the alternator is good, or the guy that tested it doesn't know what he's talking about.
First thing the, is to disconnect the alternator field wire and check resistance of the field to ground there right at the alternator. Better yet pull it off the car so you can inspect.
I hope you didn't do too much damage. Does "anything" still work? Lights?
I tried to run the "single field" original system in my 68 a few years ago, but I didn't have any luck. Every single parts store voltage regulator I bought was a piece of junk. A new one from NAPA almost caught the car on fire. I switched to the solid state system and never looked back.
Yes, battery and everything is fine. No worries.
Seems to me that having no voltage at the regulator on the post going to the field is the problem?
I'm trying to figure what caused things to burn up. DO NOT just buy another VR and hook it up you will likely burn it up too, ........unless you shorted something when you tried to jumper the wires
Before you hook up the new one........and we can lead you through this........check the alternator field for shorts AND CURRENT DRAW, and unhook the VR field wire (green) at the VR and at the alternator. This will leave you with a green piece of wire hooked to "nothing." Now check resistance at one end to ground. It should be "open" or infinity.
Take a jumper lead from the battery and hook in series with your meter in the AMPS position and the other end to the alternator field. It should not draw more than say, 6 amps max. Loosen the belt and turn the pulley. Should "average" some reading, post it back Refer to your shop manual. This procedure is in there
Pretty much a comedy of bad parts. The new VR AND Alternator were bad. Got both today. Works perfect.
Simple tests that can be done. I will put them here to help others.
Vehicle and key off.
1. Test voltage at battery. Should be 12.7-12.9 volts. If not battery is low and needs charge or is bad.
2. Test voltage at “batt” connection on alternator, should be pretty much same as battery. If not wiring through bulkhead, gauge, battery cables are bad.
Key on vehicle off
1. Test voltage at input plug on vr, should be similar to readings above. If not bad wiring through/from ignition.
2. Test voltage at output on vr. Should be similar to input, If not bad VR
3. Test voltage at “fld’ Lug on back of alternator. Should be similar to reading above. If not bad wiring from VR to alternator.
Key on vehicle on.
1. Test voltage at battery. Should be 13.5 or greater. If not alternator is bad.
If tested in this order. It is simple to diagnose.
Tests to do on new parts.
Test new alternator in the store.
Test VR in the store. Make pigtails to attach to a battery in the store. Input to positive terminal of 12v in store, ground to negative terminal and multimeter on output and neg battery terminal. Output should be similar to battery being tested on. Parts store stuff is junk. Test it before buying. Don’t waste your time.
Thanks for all the help.
If you knew all this why are you askin us?
1...Seriously, though "parts store" test benches leave a lot to be desired. You CAN NOT really test an alternator without a full load and big enough motor to drive it to full load. The 1/4hp motor used on a typical test bench "ain't it"
VR might be a different matter, but that doesn't mean the parts store tester is "correct."
2....So far as your battery vs alternator stud test, this basically does not tell you much because it is not tested under load. There can be considerable resistance in the "charge path" from the alternator to the battery and you will get that reading WITH NO CURRENT going through that path
3....As I mentioned before TEST IT ON THE CAR. If you do this correctly there will be little reason to doubt your findings. I have no idea, at this point.......why you got smoke from the harness........ You didn't say if or what you found. THIS MIGHT MEAN there is still an intermittent short and the "smoke" might return.
4....YOU ARE NOT DONE YET!!!! You (the rest of us do/ did) likely have voltage drop in the ignition harness which will caust the VR to run over-voltage. Get the car warmed up and run long enough to get the battery "normalized." Check voltage at the battery running fast enough RPM to keep the alternator activated. If you read much over 14.2, you need to check the following:
5....To check for harness drop, Turn the key to "run" with the engine stopped. Hook your meter to the closest point you can get (electrically) to the VR IGN terminal, and the other lead to battery PLUS
What you are hoping for is a VERY low reading, the lower the better. Anything over about .3V (3/10 of one volt) you need to look into why
Also be CERTAIN the VR is grounded properly with the mount, and that you have a proper jumper from the firewall/ VR or at least the front fender / rad support to the battery NEG. I like to add a no4 "starter" cable (eye to eye cable) from the rear of the drivers side head to the firewall, such as the master cylinder stud mount
I didn’t know all this when I started!
I agree that the parts store bench is not a good test, but out of the box if the store says it’s bad, like one of them today, grab another one.
Too crappy out to drive it on muddy roads today so i have to wait for a full run to determine over charging. No idea why jumper around the VR melted the wires. There was no resistance on the fld wire.
Also the vr706 and a 2 field alternator hooked right up without any trouble. Just needed a 1/4” spade connection instead of the ring connector. No additional wiring needed. The MoPar above didn’t work right out of the box.
What was the outcome of all this? I have basically an identical problem.
Alternator read low in car; I ordered new one, it didn't charge either. Thought I'd get them tested before I ordered a new VR (the current one can't be more than a few years old). Autozone gave me the green light on both alternators, Advance auto says the old one is bad (haven't had them check the new one yet).
Thought I'd do my own electrical testing and half-assed it, causing a massive short to ground, absolutely frying the fusible link and the bulkhead connector. I'm going to start by rewiring the charging circuit directly to the battery, but I don't think that's going to solve my VR troubles.
YIKES!! If you "let's say" shorted the main alternator wire, you likely did not hurt anything as long as you did not burn up wiring in the harness itself. If the fuse popped right away you might be lucky. In other words you might only have to replace the fuse link.
If there was a lot of smell/ smoke/ melted plastic, there's only one thing to do..........Pull out the underhood engine harness AND pull out the dash harness and repair/ rebuild them What happens is that wiring melts together in the harness and welds wiring together. It can be evil. BUT you can often unwrap them and repair them with a few new wires
So far as store testers, NONE of them (that I'm aware of) are able to fully test an alternator under full load. This is why you need to learn to test on the car
Further, often the car wiring is the or part of the problem. This can be bad connections in either the field or output side of the wiring. By bypassing the regulator AND field wiring to start out, you have elimanated quite a large part of potential problem. At that point you can easily check voltage between aternator output (stud) and and at the battery...........these two readings, then, will tell you if the wiring path between alternator and battery is healthy
Well the car wiring is definitely part of the problem now! Hahaha... there was definitely lots of smoke, but as far as i can tell the only connections that are actually fried are the charging wires to/from the ammeter through the bulkhead connector. But that means the dash has to come out, so i may as well take a close look at everything.
I’ve been reading all your posts on testing the alternator in the car. It’s definitely new to me! To get the field circuit out of the way, would you jump the field terminals on the alternator to ground, or to each other?
What year is your car?
‘72 scamp
Thanks! I’m definitely gonna take the opportunity to clean up the po’s hacked gauge installations
‘72 scamp
OK. By the way you have a shop manual? You can download them, free, from MyMopar
The way a 70/ later system works:
The alternator has TWO field connections, often incorrectly called "dual field." It is correctly an "isolated field" meaning it's insulated/ isolated from ground........the two connections.
One end is light blue which is switched power from the key......same as feeds the ignition system The green wire goes back to the regulator, and the regulator "controls that ground" so to speak, to control voltage
The regulator MUST be grounded to work
"To test" you need to visualize the separate circuits. the field circuit (same as ignition feed) is low amperage. If the car runs, it is likely the blue field wire is feeding field power
Remove the green field wire, and ground that alternator terminal with a clip lead. This should cause the alternator to produce full output, going up as RPM goes up. If it DOES NOT, it might be an alternator problem, or you might NOT be getting field power, or the output circuit might be open / poor connection
To find out..........low or no output.......
With your clip jumper connected, key in "run" check voltage on the blue wire. Don't unhook anything. Blue (at the alternator field) should be close to battery voltage. If you disconnect/ reconnect the jumper clip, you should get a small spark in subdued light. This shoes the field has power, and is drawing current.
Next, with engine running to simulate "medium cruise" RPM, check battery voltage AND compare that to the alternator output stud. If the battery is quite low.......12XX or less and way below 14.........and if the alternator output is quite high........15.......16 or more. then the output (charge wire) path from there to the battery is "open".........bad connection
If that point is same as battery, and is low, then you likely have found a bad alternator
If this test DOES cause the battery voltage to rise, meaning, the alternator is charging, then either you have a field circuit wiring problem, or the VR is bad, or not grounded. We recently had a guy with a bad (shorted) green wire.........which goes from the alternator field to the VR field terminal.......so a "one wire" problem can happen!!
I do have a manual... very helpful for sure. Thanks for that in depth explanation! That’s the sort of thing I need.
I’m planning on doing a mad-esque type upgrade. I see that the electrical experts here, you, crackedback, and slantsixdan, don’t entirely approve of it, but I haven’t been able to find out exactly why. I am going to run a new fused wire straight from the alternator to battery, but I still need to keep power to the welded splice. I don’t exactly like the idea of just looping it back to the starter switch, but I don’t know why that would be a bad idea. The main thing I guess is to keep the main charging circuit out of the dash.
