55 amp alternator, the max you should need is a 60. The car likely runs on about 20-35 amps and with the relay kit dragging directly off alternator charge stud, that will be even less.
Watch some bill nye science guy... Or "This Old Burned Down House" LOL If you want some help or one of the maxi holders I have, just send me a message.
I read you OP. You already have a fuse holder/case. Put that in line and put a 40 amp fuse in it. If that blows out, you need to go up in fuse rating to a 50.
