CHARLES FEARNEYHOUGH
Active Member
I was recently working on a 67 Dodge Dart Conv that I had installed a Holley Sniper on some time ago.
With the EFI, electric fuel pump, MSD, tunes, and modded headlights I also installed a 110 amp internally regulated alternator (and the required wiring to handle the additional load).
While working on spark delivery I managed to nail myself pretty good
and, apparently, blow the regulator in my alternator. Luckily the EFI is still alive! After working on it I noticed 17 - 18 volts on the sniper display. Not wanting to shell out the 200 bucks for a new alternator I picked up a Mopar regulator from a local store and used it to supply the field voltage externally. This worked fine albeit the voltage seems a bit high for my liking hitting 15 sometimes but generally in the 14.2 to 14.6 range. Amperage draw on the field is running 5 to 6 amps which seems high to me as well. There is no AC coming from the alternator so I don't think the diode packs are damaged. Thinking that the issue might be the failed regulator I removed it, reassembled, and saw no change to field amperage draw. Found a replacement internal regulator on Summit and ordered it. Will see if that reduces field current and output voltage. Moving forward I think I'll stick to externally regulated alternators
