14.6-14.9volts the sounds is around 2500/3000 rpm
Sometimes I get the odd 15.1 volts.
I just picked up that mopar voltage regulator. I currently have a cheap silver one. I'll install it tonight and see if it changes anything
As Dave said above you likely have a voltage drop problem
There are several ways to check for it, here's how I do it:
Turn key to "run" engine stopped. Stab one probe of your voltmeter into the top of the POS battery post. Hook the other probe as close as you can to the regulator blue. This will be either at ballast resistor or the blue alternator field wire
You should measure a very low voltage, the lower the better. More than .3V (3/10 of one volt) you need to look for the problem.
Example: If your regulator is properly regulating 13.8---14.2, and you have 1/2 volt of drop in the above test, your battery will charge at 14.3---14.8. In other words the voltage drop causes charging voltage to RISE by the amount of the drop
Also, the ground circuit can be a problem.........
Run engine, fast idle, test with all loads off, and again, with lights, heater, etc running
Stab one probe into the top of the battery NEG post. Stab the other into the mounting flange of the VR case. You again should read VERY little voltage, the less the better, ZERO is perfect
