There are plenty of threads regarding these heads. I believe some are stickied at the top of the page. They are basically god to go and many prefer them to Edelbrock heads.
If you can hold off till Nov, they are usually 40% off through speedmaster's black friday sale. That's when I bought mine
i'll et you know i just bought a set
Yes sir - make sure u post sale when time comes if you can I want to buy some bare for future build .If you can hold off till Nov, they are usually 40% off through speedmaster's black friday sale. That's when I bought mine
Don't hold your breath. I believe this November will be a little different.If you can hold off till Nov, they are usually 40% off through speedmaster's black friday sale. That's when I bought mine
But suing for 30 cc's? Heck, the factory cast heads were that far-off.Heres the most recent thread
Lawsuit anyone?
u need some BB aluminum SM heads? I have the offset rockers too.... LOLDon't hold your breath. I believe this November will be a little different.
If you want a part you better get it ordered and don't wait for a sale that may never come.
well i got the heads , they look good so far , chambers measure 65cc which is what is advertised. As for the rest they will be flow tested and checked top to bottom next weekAwesome thanks!
You might want to search out my 390" stroker build, there are some OFTEN overlooked issues with the speedmaster small block headswell i got the heads , they look good so far , chambers measure 65cc which is what is advertised. As for the rest they will be flow tested and checked top to bottom next week
That's OK, Thanx anyway. The only imported big block head I'll use is the 440 Source head.u need some BB aluminum SM heads? I have the offset rockers too.... LOL
lol... i was jok'n..That's OK, Thanx anyway. The only imported big block head I'll use is the 440 Source head.
as far as I'm concerned with a little work it's the best budget big block head out there.
I knowlol... i was jok'n..![]()
For a couple hunder bucks more you can get a set of Promaxx heads.
And are they any better coming from China? KimFor a couple hunder bucks more you can get a set of Promaxx heads.
I think they are the same casting as the China Speedmasters but with a quality 5 angle valve job and pocket ported. Promaxx buys them bare and build them per order. Mine took about a month and showed up today. Look good to me. Customer service was good. They have good quality control. I've heard nothing but good things about Promaxx.And are they any better coming from China? Kim
I can post some pics tomorrow. I'm beat from working in this heat. They are shrink wrapped and I an leaving them that way until I can fit them.Have you taken any valves out? Would you mind posting some photos?
