Aluminum raidiator
looka alot like the griffin i put in my dart from summit.. mine was like $190 mine is 24" wide 19"tall.
yes thats the rad. no leaks or problems... you know i don't remember how long the angle was.. i could measure it for you if you want. i didn't even have to drill holes in the car to mount it. it bolts to where the a/c condensor wqould bolt. the oval holes on the rad support.. it cools the car very well.. still heats up at idle but thats just because i have no shroud and the fan is so far away from the rad. if it creaps to 200* at a stop it will be back down to 180* in about 2 blocks. i have had an electric fan sitting here for a while now and that should take care of the problem. i just have to get off my lazy *** and put it on..
