American racing wheels and willwood brakes
GDart
Sacramento, CA
Want to know if any of you have been successful in converting to Willwood disc brakes and using American Racing wheel (Torq Thrust D 15")?
I'm in the process of converting a 69 Dart from drum to disc brakes and was considering a Willwood front brake system. Talked to the Willwood tech and it appears none of their products are compatible with 15" Torq Thrust wheels?
Thanks in advance
tent.speedwaymotors.com%2FProductImages%2F120VN105017_L1600_815371bd-dd74-458d-9dde-6a640b7c65b8.jpg
Unless you just gotta have the Willwood stuff, look at Dr Diff's disc brake swap options. Way better setups without limiting your wheel options. Well, limiting to a degree depending on what size kit you go with. Plus, some use parts you can pick up right at any auto parts store when you need replacement parts.
His website: Doctordiff.com has a well laid out table of brake packages and what they will fit with.
We put Wilwoods and 15 torq thrusts knockoffs on my friends(superchargeddrt) 69 swinger.
