In the process of doing my 440/512 engine rebuild and redoing some of the EFI/Coil Near Plug wiring, I need a 6 foot length of 3 wire shielded cable for my cam position sensor.
I thought I had some here. Nope... Needed to get the wiring and harness finished so did not want to order and wait.
SO, I made my own.
I had the correct 3 colored 18 gauge wire.
What could I use for the shield?
Lets see.... Being a Ham Radio operator, I have some short random lengths of RG8 coax laying around.
Found a piece close to the length I needed and stripped off the outer rubber coating and slid the woven copper shield off the center conductor.
Then taped the 3 wires together and pushed them through the salvaged copper shield. Should work better than the minimal shielding that comes on most shielded cable.
SO, I made my own.
