BlackBrick
The Cult Mechanicus
I know, I know, you guys see this question all the time, but I have a few questions about installing a high amp alternator in the Brick. :banghead:
In the very near future (hopefully this coming weekend) I will be adding 2 audio amplifiers to the Brick. Current plan, because of lack of amperage output of the system, is to leave the subwoofer amp unpowered until I can increase the amperage output in the system.
Currently, I am running a stock style alternator, presumably a 65 amp, since the car came with some of the elctronic goodies that were offered way back when.
In looking at the instructions here: http://www.allpar.com/fix/alternator.html
I have bypassed the amp gauge as per the instructions for MAD enterprises, but did not wire in a new ammeter or a volt gauge, just soldered the wires from the ammeter, and added the fusible links at the relay.
In order to add a 100+ amp alternator, I need to run a 6 gauge wire from the alt to the battery (or lug on the starter relay), 10 gauge fusible link inline with that (I plan to use the Tuff Stuff 100 Amp model from Summit). This is mostly to prepare for the inevitable "more amp using" installs down the road (electric fans etc)
My question is, will the 6 gauge wire be solid enough to run from the Alt to the starter relay going around the stock wiring position?
I saw a post here somewhere about the need for a larger gauge wire the longer the cable (current planning is about 8 feet-ish, with the 6 gauge wire)......
And do I need to re-wire, with heavier gauge wire, for the field wires and upgrade the voltage regulator?
I am trying to get the ducks in a row so there are no surprises to the wife and no burning of the Brick because of bad wiring decisions.
