I swear to whoever I can swear to this is true so far as memory 'members
Many of you know I was stationed at NAS Miramar, our shop and one of the shop trucks at left. The black '64 and the limelight '70 are mine
Just recently I ran across the phone no. of one of the guys I worked with, and we talked quite awhile.
We had two nearly identical 63? Chev pickups for our shop use. One of them would get jammed in gear, between 1st and 2nd "3 on the tree" and jam in I guess 2nd gear
One day we were coming back to the shop from the RADAR trailer over across both runways, so we called the tower for clearance:
"Miramar Tower, Ground Electronics 61, permission to cross 24 left, 24 right, at Queen 6?"
"Miramar 61, cleared to cross 24 left, 24 right.............(pause)...........MIRAMAR 61 EXPEDITE EXPEDITE!!" (aircraft in the pattern coming to final)
My friend Dave (guy I just found) was driving, wound it up and mashed it towards 2nd gear AND BROKE THE SHIFT LEVER RIGHT OFF about an inch from the column collar!!!!
So we "nursed" the thing to the shop. This was either a holiday or weekend, there was just the two of us. "Oh Lordy what will we do, we will lose stripes, bla bla bla.............."
Then I lit up.........."LISTEN WHICH TRUCK IS THIS can we get it STUCK IN GEAR??"
Well it was the OTHER truck..........so we went out, found a pin punch, fiddled around with the other truck until we got it stuck in gear, THEN DROVE THE PINS OUT and SWAPPED THE SHIFT LEVERS!!!!
That's my story and I'm stickin' to it!!!
My mother had a Nash Metropolitan. For whatever reason she just loved that little thing. It used to get stuck between 1st and second, she had an old tire iron behind the driver's seat and had no qualms about crawling on the ground with that tire iron to line everything back up. BTW 8 people of various sizes will fit in a Metropolitan, been there, done that.
