madmoparmick
I say have a little faith and respect for your friend who built the motor and put
it in like it is. I'm sure it will run great. You didn't mention which Weiand, but
whatever you got will do. Make an effort to match head ports to manifold.
Block heat passage. Use heat spacer under carb. Speaking of carb- 650
(dbl pump?), or 1850 600 cfm vac secondary? If vacuum, use lightest spring.
Set up distributor for quick advance and time for 36-38° total advance. It will
be a fun car with that 4 spd.
