any home window installers here
Snake
Mopar Nut
Belleville Canada
Well we are down to 2 windows for this old house.We have been youseing a great company, but there are 2 on line that is almost a perfect but there is only like 1/8 on each side for the spray foam is this enough or should there be a bigger cap,they are going in an wood frame, retrofit the 2 windows are new never unwrap and a great deal.Thankssssssssssssss.
IT'S GAP!
GAP GAP GAP!
Sorry Don, I had to. :D
1/8 gad is fine, just move a little faster.
You just might have to cut off more foam if you use the hi expanding stuff.
Had to do that too. :D
Don I'm really glad you took that the way I meant it.
Thank you.
In real life I'm a total smart *** and I like to think I can take it as well as give it.
It's all in good fun to me.
Have a good day my friend.
X2 on the LOW expanding foam. The other kind can force things into a bind. Many "replacement" windows have a foam strip around the outside edge where it hits the wood vs the "new construction" type that have a flange.
What do you guys think of warranties now a days,Cindy had a good point if we buy thoes there is no warranties,where as if we use the guy we have been buying from we have a hell of a good warranties .She may of just rain on my party,or did she.
Built my house in 1994 and installed Anderson low e thermopane windows. Out of the whole house the kit. Window had to be replaced after many years. They took care of it
If you get a great deal, and had to replace one later on your dime, how much would you be out?
If they are new name brand windows what kind of warranty do they have?
I had to give Anderson the info off the glass before they sent me a new panel.
Also do these windows match your other windows?
If it is a deal, the size you need and look good, why not! If they are cheap DIY bottom line windows probably not a good deal
As a few have said low expansion foam. Dad n I replaced all my main floor windows with North Star. Great windows with a great warranty.
If we had to replace booth windows 600 the windows are all weather from Home Hardware ,they look the same as the outher windows but the lock looks cheep.
