70DusterBob
If it came out with those gears on it then;IDK what caused that. Those spider gear teeth look almost new.
I've seen a lotta rearend carnage since 1972 but I haven't ever seen that combination.Put a SureGrip in it and that will never happen again
What's a JY?
The smallest rearend that will live behind a 408 is a Mopar 8.75, and it should be a clutch-type 4-spider Trac-Loc . Unless..... of course......... you got skinny tires. But I don't see the point of 408 plus skinny tires. That's just a recipe for disaster. And a big old embarrassment when a big-tired 360 throws dirt on your hood. If you peg-leg your rear, it won't be long before the crosspin retaining pin gives up the ghost and the pin launches somewhere; hopefully not into the gas tank, cuz it might be super hot. Remember when peg-legging, the spinning axle is doing double what the speedO says! And the oil temp is rapidly rising, cuz there just ain't a lot of it in there.And if you happen to be going around a corner some of it may not even be in the sump.
Sideways is the whole point of a 408 isn't it? Just remember skinny tires don't brake when going sideways. They just slide and slide and slide 'til you hit something.
I thought this was rather odd as well. JY is Junk Yard. It is a 8-3/4, but I can't imagine for one, how this kind of wear occurred, but secondly, how this pin held up under that much torque.
I was afraid that having the tall, 2:72's in it did this because motor was trying so hard to move the car, I guess that's out huh? That's good, because I will probably, eventually go with a better gear combo for the 408's torque.
I appreciate your explaining that the axle is doing twice the speedometer indication. Wow!
If both tires spin on a straight away, and only one on a curve, what type of rearend is that? Trac-Loc?
Bob
