txstang84
I'm betting it probably would feel a bit soggy on the bottom end without appropriate gearing and stall...
It would also be nice if a much smaller engine had as much torque down low as the larger one does, but they don't. MOST street combos need more torque, not more top end.. Simple. Core 360s are almost as plentifull as 318s, machine work costs the same on both, parts are similar...just no reason to build a teen....Sure would be nice to read just one teen thread, without all the ditch it for a 360 comments.
Ok, then, I have no problem with a 318 build, I have built plenty of them myself. And nowhere did I "trash" a 318, its just not the best street choice in my opinion, considering he will need to buy heads, or spend coin to make them flow enough for his power goal... and still make LESS torque than a 360 built in the same fashion. But I bet at the end of the day, its gonna cost LESS to build a 300-350 horse 360 than the 318... and then we got to talking about 400 HP magazine builds... the 318 at that power level is going to cost more, period.. Now, really he said at first he didn't even want the car to be fast, he just wanted a cruiser, so I would just run the 2 barrel 318 and be done, in that caseSure there is. And I think you missed it! He alllllready has the 318.
It's easy to sit behind the key board and spend someone else's money.
"Sure! Get yerself a 360 @ *** amount and then Go from there!"
Why not? It ain't your money! If he wants to do a 318, help him instead of trashing the engine and choice.
I will not argue bigger is better, at what point is it really worth it all for it? The limits change per person and the goal sought.
It would also be nice if a much smaller engine had as much torque down low as the larger one does, but they don't. MOST street combos need more torque, not more top end.. Simple. Conk when re 360s are almost as plentiful as 318s, machine work costs the same on both, parts are similar...just no reason to build a teen....
Um......... ok, good find for you!I bought a 74 Dart for the disc brake swap to my 65 Barracuda....discovered it had a frisky low mileage 318 w/headers. Sounded much better than my tired 273.
Upon opening trunk when brought home, discovered an Edelbrock Performer intake stashed inside.
Decided 318 was going in Fish.
Was your rant for or against the 318?
You guys are hilarious..... FIRST of all this is called a "discussion" as the ORIGINAL post was just commenting on a magazine buildup. What follows after that is the pros/cons of it. Please post where someone was "trounced" if you will kind sir....For, Since in my opinion they are all good, why trounce someone if he or she wants to build any small block. He did not ask "should I build a 318 or 360?". Why answer a question that was not asked?
