Anyone Auto-X their early A's?
Curious of your set-up from wheels/rubber and suspension spec's...
...pic's would be awesome too!! :)
As John Mentioned, Here is my Grüne Hölle '64 Dart.. Every thing you ask is documented there except Tire Pressures and Alignment..
↓↓my notes and setup data for me to reference from 7/21/21↓↓
Alignment:
Caster +5.5°
Camber -0.75° ( I have the Thick Washers and Proper Grade 8 Bolts / Nuts - Will be installing them before Next event for -2.75°) (I bought longer bolts and some More grade 8 washers to add eve more - Camber as needed without having to do a total realignment.)
Toe 1/8" Toe In
1.03" Torsion Bars
1.125" Front Sway bar - Not adjustable - (Where can I source Adjustable Links for it?)
12" Long 200 In/# Coilovers rear on Reilly Motorsports 4 Link Setup.
Full Frame connectors Added, Torque Boxes Added
Corner Weights With 3/4 Tank Fuel, Driver in car and Driver Gear:
3226#
LF 711 RF 901
LR 697 RR 917
Dave And Matt Probably have More AutoX Laps and development than I do. As Matt G has shared with us..... Mr. Mapes' Documentation is superb as well for both the Mustang, Dart and Barracuda.. I should read up on his notes.
Greg
