Anyone got a pic of neutral saftey switch wire connection placement on bulkhead?
1970dartcustom
of the Moore clan
Broken Arrow, OK
We cannot seem to find out exactly where this neutral safetey switch wire connects to the bulkhead... Anyone got a pic??? 1970 Dart
I just hooked mine up today,, Too late to get a pic for you but right by the "block of wires" where it goes thru the bulkhead I have a dark grayish plastic with about 3 inches of wire,, the male ends inside the square plug are angled.. I have a 70 Swinger(2 wire) and trans came out of a 73(3 wire). so I had to crimp female connectors on to those 2 wires and connect the brown wire that comes from the regulator right by the battery.. Hope this helps.
For many years the far right bulkhead connector was referred to as "wiper motor connector". That's because it had no other wires in it. In 68 model they moved the reverse lamp switch out of the cabin ( previously shifter mounted ) and down to the trans. So, these 2 wires went through the previously unused ports of that far right bulkhead connector.
The brown neutral safety wire always was outside the cabin. Routes directly from trans switch to starter relay. If you need to route it into the cabin for some reason, pick a port. :)
