Does anyone out there actually have a 1968 Carter 4425S carb? If so, could you please do me a big favor: look at the end of the butterfly shaft that connects to the fast idle linkage and tell me if the peened edge contains a bent tang or if there is a separate part next to the peened edge that has the bent tang. I'm getting conflicting stories(most with later carbs) regarding my previous question and I want to make sure before I start swapping shafts.
Attached is a photo of my 4425S. The end of the shaft is perfectly round and there appears to be a piece missing that would go next to the peened end.
