Anyone run the Weber knock off 38 progressive 2bl here on their 225?
To my knowledge, Clifford only sells two intakes. One open plenum that you buy an adapter to fit your carburetor and a dual Weber intake. Both of which are water heated. At least, I would think the dual Weber intake is water heated. I know the other is.
I think the Clifford I had the water box was cast in. I never used the intake. That or the Offy. There has been several models of the Clifford 4bbl. One had the bosses with the water box. One didn't have the bosses.
It looks like you need an adapter to run the 38 on the two barrel intake- I got it from you Rusty IIRC? Soaking the weber now, it's froze up, got my redline rebuild kit, soon as it is rebuilt, putting it on the manifold.
Yeah, there's an adapter for a Jeep 258 I believe that will do it.
