Anyone running the Hoosier 275-55-14 Quick time Pro Dot Tires?
Kevin Jonker
Yucca Valley, Ca
I may need to go to these as the M/T SS Indy Profiles are getting real hard to find. I hope they will fit my 68 FB fish. The M/T SS G-60-14's just fit. Do they hook reasonably well? Especially if heated for the track? Thx. Kevin
I run them on my 67 barracuda FB, on 14X6 1/2" wheels they fir great, have excellant traction. they are 8.5 inches wide for the tread..best tire combo I could find for my 14 inch rims...Only problem I have is I ordered from jegs, tires have cracks in the sidewall, I believe they had been on the shelf for quite some time, probably an uncommon size, so make sure the ones you get are recently manufactured....I just did a 1.60 sixty ft. last weekend with these. unbelievable. @ 27lb.
Thx Ranger Rick. How have they lasted with around town use? Also I called them quick time pro dot when I meant the quick time dot tire with the actual tread pattern.
