Anyone using the Moroso #93174 pan gaskets?
VF Coupe
EFI DART
Cypress
Hey,
Is anyone using the Moroso 93174 Bigblock pan gasket with success ?
It looks to be quite thick times that by two < including the windage tray >.
How have you all gone ??
Im keen on this as cork ones squish out and always leak !!
The beauty of a big block Mopar is to not have any leaks right !!!
As Mother Mopar gave us all a perfectly flat pan rail to begin with !!
Go the Big block A Body's ............ anyone else??? come join us in the land of big !!
:burnout:
Just wondering if you used the Moroso 93174 oil pan gaskets?
If so how did they work out for you?
I bought them but had the same question you originally posted that they look thick using 2 with windage tray?
Got them because I could not get my stock pan to seal using Fel-Pro 1834 gaskets.
Thanks
That tray looks awesome!!!! I used the Moroso gaskets though because I had them already. Wish I knew about that before I bought them... Oh Well.
Just finished getting the Pan back on today and will test it sometime this week if work allows. I let you know how it sealed.
May try that pan in the future if it doesn't seal. Has anyone tried this new tray yet and do you use any sealant or RTV?
Thanks for the Info
I went the jegs and Mopar Engine RTV .
Don't leak at all been great :cheers:
