Almost looks like the coil wire is arcing at the coil. See the discoloration?
Looks like my center wire was the culprit, tracked and has small cut in sheath under the boot.
Yep! Never overlook the obvious.
taadaa!!Plugs are autolite 66, wires are 8mm “suppression” so I assume both are resistor?
