are these correct ?
ive never built a /6 , but i just put together a 440, and that thrust bearing is way wrong. it should fit snug in the grooves. the rest look wrong as well.
Take a good look at the block. How many freeze plugs does it have? What is the casting date? There should be some numbers stamped on a pad at the passenger side front of the block deck. What do they say?
+1 get the numbers.
Looking at similar pics of my forged crank block makes me think yours is the later cast crank style.
