pishta
I know I'm right....
absolutely...I got an MS2 and another controller that I may adapt, although the original ECU/controller is already burned for this cam, but its stroked (360 to 40x) so I dont know if I can increase global fuel flow 18% with the stock controller? Could just increase injector size by 20% or even fuel pressure It has a non adjustable fuel pressure return (hosed piece on rail) but you can get adjustables with a small screw for cheap.That would be a good setup if run with a modern ecu like MS or AEM Infinity
