DrCharles
OK, now we're getting somewhere. Yes, you can keep changing things but that costs money too (and you'll never get anywhere near what you paid for the old stuff). Try and hit your target the first time...
Tell us more about your planned engine. A stock 360 rebuild? Not going to run 10's with that. Do you already have the block or any parts at all? Look at stroker kits if you're going to be buying a rotating assembly anyway. "No replacement for displacement" ;)
Finish line RPM for a modestly priced smallblock will likely be no more than 6500. Yes, you can build a smallblock that turns 8000+ but you aren't going to like the price of the valvetrain, heads, rods, etc. necessary to do that. Now plug 6500 and 28", optimistically 120 mph trap speed, into an online calculator and you get something around 4.30 gears. Definitely driveable 10 miles to the track since you'll be turning half that RPM (3250) at 60 mph.
Remember that a 5000 stall converter can be driven on the street depending on its internal design (and oil cooling, and weight of the car)... it does NOT mean you have to rev to 5000 before the car will move! It only takes about 20 hp to cruise at 60 mph. There are lots of different options from the manufacturers, and (as initially pointed out) that's why they need to know your combo before they can build you one.
I really recommend you start with a realistic budget for the entire project. That will to a great extent dictate how fast you can go, as the ancient quote summarizes. Do you have any idea what you can invest in the engine and the car?
