ramcharger
Dismember
Anyone ever consider using an AX15 in their A body? I've heard of it handling 400hp in Jeep LS swaps with ease assuming it's been taken care of. Seems like it could be an interesting 5 speed option..... Or maybe i'm just insane.
I would cruise some Jeep forums and see what they say. After real quick lookin, I see things like "for s 4.0 they are good but not for much stronger". And "they're garbage". Not my opinion, as I have none. Just what I found in 30 seconds.
Well, what the hell. Blowing **** up is half the fun. I plan on destroying my old drag bike with a 75 shot of nitrous this year... Btw, it's only 600cc.All I can say is try it. I'm gettin ready to put a world class Tremec T5 in Vixen, so I'll be seein if that'll hold up too. That's what it's all about, right?
You might not blow it up. lolWell, what the hell. Blowing **** up is half the fun. I plan on destroying my old drag bike with a 75 shot of nitrous this year... Btw, it's only 600cc.
I shift @ 12K rpm and run it out to 13K. I'll pull 4 degrees out on the box at the hit and lock out 1st and second gear since I'm old school and still foot shift, lol.You might not blow it up. lol
Interesting... Probably couldn't handle launches with sticky tires?i personally ran a AX15 behind a mopar performance 360 tcrate motor in a 93 truck. BUT, i only put 50 miles on it before i decided to put a stroker big block in with a 727. I cant recall if i hammered down on it any. but it drove the 50 miles with no problems on the highway. i drove it from nashville tn. to the drag strip in bowling green ky. and back. i had 4:11 gear in an 8 3/4 in the truck with big tires. dont remember the tire size but the rims were 15x14 with big *** Coker tires
I did not realize "big ***" was a tire size. Learn sumffin new every day. loli personally ran a AX15 behind a mopar performance 360 tcrate motor in a 93 truck. BUT, i only put 50 miles on it before i decided to put a stroker big block in with a 727. I cant recall if i hammered down on it any. but it drove the 50 miles with no problems on the highway. i drove it from nashville tn. to the drag strip in bowling green ky. and back. i had 4:11 gear in an 8 3/4 in the truck with big tires. dont remember the tire size but the rims were 15x14 with big *** Coker tires
That's one size above honkin'.I did not realize "big ***" was a tire size. Learn sumffin new every day. lol
Lol! I have a of set them as well.coker tire kinda sucks too. i drove all the way to chattanooga to buy the tires and get them mounted and balanced. they mounted their tires on my centerlines and then told me "we aint got no weights ta' balance em'" i finally found a big rig place that balanced super singles to balance them.
And one below huge ***That's one size above honkin'.
Alrighty then!That's one size above honkin'.
and this can be seen right here in the splitsand the 2-3 shift is a big rpm drop.
I could certainly see a 4 cylinder having trouble with that.Looking at the ratios
3.83-2.33-1.44-1.00-.79, splits of
---.61--.62--.69---.79
It could be fun, at least until it breaks.
