Axles
69DARTS
69 Darts Rule
indiana
So i called a place that makes axles
For my dart.
They asked me if i was going to use bbody brakes.
Just wondering why they asked that
Whats the difference in the axles.
What did you order? You can have them made a couple different ways-
Stock replacement.
Stock dimensions, but with 4 1/2" bolt circle-which means you can use stock A body brakes, but need to have your drums redrilled (and again any time you replace the drums).
A body width with B/C/E body flange offset and 4 1/2" bolt circle- this allows you to use standard off the shelf brake parts or upgrade to bigger drums or rear disc.
he wont be getting any axles unless they are custom made. others are all backordered
