Bad Rear Shock Plates
adamm
Duluth, MN
The studs on my rear shock plates are bent and have no threads left on the ends. Is there anything to worry about if I drill them out and order new studs to put in? Thanks for the advice.
I drilled mine out and used shoulder bolts from my work. worked really well and easy to do.
