wh23g3g
I've got a 65 4dr Valiant with a column shift 904 cable linkages. I took out the column to do a rebuild and even by carefully labeling the parst I've lost some important small pieces. Mostly importantly is I've losted the lug and spring on the end of the park cable which plugs into the back side of the transmission. I've got everything for the shifter cable which is the one that plugs into the driver's side of the transmission. I've looked everywhere for it and cannot find the lug and spring for the park cable. I also don't remember if I ever had or I lost what they call the wave washer on the top of the steering column between the shifter housing and the bearing housing. If anyone has some spare parts let me know. I don't know how or don't even know if I will be able to even move the car around without the shifter cable mechanism. So I've stopped all work on it.
