Ball joint part numbers
Wolf360rt
Boosted Cuda
Metamora, IL
Hey guys I have a 68 barracuda that im workin on and I know that you can put b-body spindles on the car. I just need to know a part number for the lower ball joints moog ball joints if I can get them. I have a k-member and lower control arms from a 71 dart, and 68 Charger drum break spindles any help would be greatly appreciated. I plan on getting tubular upper control arms with the correct ball joint.. and what am I gonna need for steering Tie-rod ends idler and pitman arm.. part numbers will be a big help..
Moog K772 will get you both upper ball joints and you will need K783 for the lower left and K781 for the lower right. Once you have the new upper control arms you can just bolt it together. Your steering setup will work just fine as is.
