jamesromeos
Looking to put larger tires on my barracuda, the rear of the car appears to be sagging, wondering if there was an affordable means of either replacing the springs, or an add a leaf? I don't know.
Re-arching will help as well, but it's going to be unpredictably temporary depending on the condition of the springs.
IMO, most of the suggestions here are band-aids. My recommendation is to replace the springs. Yes, it's not the cheapest option, but it is the most secure. There are plenty of vendors out there. I went to McVeigh Truck Springs for the set I put in the 73 on the recommendation of another FABO member. It solved the sagging problem and did not adversely affect ride quality.
My reservations about add-a-leaf and coil-over shocks are these. Both stiffen the rear suspension which makes the car understeer more. The coil-overs place more stress on the upper shock mount than they were designed to take which could lead to failure.
How big a tire can be mounted may depend on whether or not you move the spring inboard and how long the axle is hub-to-hub. I run 15x7 with 4¼" BS. The most I could get under the wheel wells on a 72 BBP disk brake Demon was a 235/60-15. It's very close to the outside edge of the wheel well in front and close to the spring in the back.
Wow, those are cheap. Dodge71demon how much are you asking? I assume shipping would kill me $ wise.
