Barracuda trunk letter alignment woes
swing69
I’m just an old guy……
Central NJ
I replaced my 65 Barracuda trunk lid with a 64 or 66! I thought it was 65....but it must not be.
I installed my original P L Y M O U T H letters.
Darn it ; the M is approx 1/8” lower in alignment than the all the others.
Another words, the 2 mounting holes in the lid are lower.
Any know whether it’s a 64 or 66 letter “M” I need????
Thanks
I got a set i can check when I get home tonight. About where should the pins be on your application higher or lower than centerline
There are a few different pin points. Call Rick or Dave at Layson’s. They will get you the correct “M.”
I need the pins to be lower on the M to move it up.
Crusty / rusty M is fine! All the others are that way ! Let me know. Thanks
Not much help, but the letters look identical but pins are different on the M front to rear as the 0 has an extra mounting pin to align it up
My understanding is that there are 3 different pin locations for the M depending on application.
