!!! WHOA !!! Nellie!!!! Back up thar pardnor!!!
WHY do you think you need a disconnect switch?
Are you goin' racin? You have a trunk mount battery?
IF you could "keep your radio settings," then it ain't a disconnect switch, now are it?
How 'bout postin' a dad blamb PART NO. when ya come 'round here wi' tat kind'er stuff??
I don' see no cotton' pickin' foteennandeynan SWITCH here:
http://www.jegs.com/p/JEGS/JEGS-Battery-Terminal-Disconnect-Switch/751650/10002/-1
So let's get serious. WHAT exactly are you trying to do?
WHERE is your battery mounted?
AND IF you ever plan to show up at a drag strip, there are several things that a switch must do in order to pass tech. You cannot simply disconnect the battery
1 It MUST be in the hot lead, not the ground
2 It MUST kill the engine, IE if you just disconnect the battery, it might just keep running on the charging system.
3 IT MUST meet location regulations, be easy to find, and MUST "PUSH'' (not pull) to shut off if it's a push/ pull type.
On the other hand, if you just want to disconnect the battery while in storage, there are more options.
15 bucks doesn't sound like much of a switch to me. Bear in mind that it has to be a good enough switch to carry heavy starter current WITHOUT burning, melting, causing voltage drop, etc.
