BB Spool mount inserts?
sabre67
B.C. Canada
Hi all ,Im trying to find a supplier of the spool mount inserts for these BB engine brackets. Not having much success:(.
Any leads would be greatly appreciated. Thanks.....sabre67
Energy Suspension has nice poly inserts. You have to melt the existing rubber out of the sleeve, a small propane torch works fine for this. The existing sleeve has to remain in the mount.
Good to know, but it looks like his sleeves are already gone.
The brackets pictured. I bought off Ebay and I dont have any of the sleeves your talking about :BangHead:,am I screwed?
No, you only keep the original outer sleeves if you're going to use poly inserts. The rubber inserts come with new shells as part of the mount.
No. If you wanted to go poly bushings, yeah, but if you get the stock replacements in post #2, then you're fine, because they come with sleeves.
Thanks for all you guys help .this forum is the best out there :thumbsup: FABO!
I have a couple of Energy Suspension ones left over from a project. I'll send them to you if you pay postage
Thanks for the offer Andy, but Im going to use the stock rubber ones I already have. :thumbsup:
